Passenger power seats
Another issue with my s560 (as always).
So about a month ago, my dad spilled a whole gallon of dawn dish soap in the car. I thought it would be a great idea to try to dilute it out using a pressure washer and a wet vac. I got the carpet back to its white color, but now the passenger seat power motors will not move.
The seat retains the heated features, and the "hugging when turning left and right". Also has the seatbelt working / weight sensor works, but the motors do not move up and down on the rails, and the seat does not move up and down.
Anyone got any good ideas on where I should start to fix this guy? fuses look good, but I can be wrong. Any advice welcome.
Hose did NOT work, and a carpet cleaner was not making any impact. I had to take desperate measures
I didnt let the water get too high, as I had the wet vac suck up the water all the time, I am just looking for like a "start here".
I assume the fuses arent ****ed since the rest of the seat functions work.
Carpet is dry. I was going to start taking the power seated module out to maybe swap it to see if I didnt just kill that thing.
I checked the fuses this weekend, the 30 amp and the 7.5 amp are both fine.
The buttons on the door work but the controller underneath the seat isnt communicating with the buttons.
Its going to be my first place to check, but the seat wont move forward anymore :haha:. Gotta find a mechanic to help me move things around, I found whole working modules for 150 on ebay. itll be a good start, because the modules chill underneath the seat, where the water and the soap could have gotten.
To do this right the carpeting needs to come out of the car and the padding and sound deadening underneath it likely needs to be replaced.
Thank you for the idea, but all I washed was the foot section of the seat. Yes there were wires but no devices, I was thinking maybe the water crept with the foam padding.
Youre absolutely right Ill check out who can do that kind of labor, but I want to make sure the seat function is restored before I go to MBZ and order a new interior padding.
all COMMAND functions work fine (lumbar moves, massage ***** kick in, heated ***** etc work), but the manual controls on the side do not work.
this guy shows serious corrosion damage. Replaced him and I got MOST of my seat functions back (front back headrest up down), but the chest piece isnt moving around. Im going to assume the plug has some corrosion and needs to be cleaned. The fans work, and heating unit activates.
250 price tag
if you are so inclined, you may want to take a look at this video (
I purchased a part that someone claimed would fit.
Installed it, Front back and headrest movement returned, but back piece would no longer move.
Purchased the "RIGHT" Part from MBZ for 200 bucks, and all features returned. all motion/mobility.
I am currently getting an error that is screaming at me to "get the part repaired" but ill just assume its an error flag that needs to be reset @ a dealership or dealership computer.
Ill keep you all updated on my journey.
