HELP! Seeking a coolant expansion hose (tube)
A-222-501-50-25
A-222-501-50-25
Does anyone has a car they are or know of that is parting-out (breaking) that I might be able to find a good, used replacement in the interim. I found a Chinese replacement hose but shipping takes 3-weeks.
Thanks in advance!
This plastic pipe goes to a regular hose on the engine side. You can see the hose part sticking out of the engine, So that part you can just run a small coolant hose.
Get a few feet of hose, same diameter as the one in the engine. Bigger, smaller, mix and match. Hose is cheap.
Mine broke too. They all break eventually. If you look at them too hard they will break, and while waiting for the part I ran a regular coolant hose from the engine, cut the plastic hose and fitted the coolant hose over the plastic pipe with clamps. Drove like that for thousand miles at least.
Yours is tricky, as you have to run the hose all the way to the coolant reservoir and then find a way to connect it, but I am sure you can cut something to fit the hose over it.
The little nipple pipe on the engine will also probably break if you mess with it. The part number on mine was 009-997-29-72
