S-Class (W222) 2014-2020
SWITCH STUCK IN SPORT MODE
Old Oct 4, 2022 | 11:56 AM
autoluke's Avatar
2003 S430
My sport/comfort switch is locked in Sport mode, and will not make the change when pressing the C button.
Is this software related, or perhaps a defective switch ?
Old Oct 4, 2022 | 03:43 PM
aeggroup's Avatar
2025 Range Rover, 2022 BMW M850 , 2017 MB E400 Coupe
Haha....some people pay extra to have a bug like this
Old Oct 5, 2022 | 04:08 AM
BenzV12's Avatar
W212 FL
This should be the best stuck ever although you would not need Sport mode all the time at all
Well, it's hard to tell from here but a software glitch should have more possibility over a button failure
Old Oct 5, 2022 | 02:26 PM
Sactownmb's Avatar
MY 18 S450V RWD Diamond White
If we are talking about your 2003 MB then my money is on a bad switch. In service for 19 years is a good run.
Old Oct 5, 2022 | 03:02 PM
autoluke's Avatar
2003 S430
Car is a2015 S550.
Old Oct 5, 2022 | 03:15 PM
konigstiger's Avatar
'71 Pinto
You can remove switch block to check for proper switch operation but may be best to have someone pull fault codes using MB diagnostics could be failing sensor.
Old Oct 6, 2022 | 04:19 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
The vehicle described should default to C mode at every startup as configured from factory (button working or not). When did this behavior start?
Old Oct 27, 2022 | 01:42 PM
autoluke's Avatar
2003 S430
Drealer reports faulty front sensor...does this make sense?
Old Oct 27, 2022 | 02:05 PM
VII's Avatar
VII
Faulty front what sensor?
Old Oct 27, 2022 | 02:09 PM
autoluke's Avatar
2003 S430
LEFT FRONT LEVEL SENSOR...
Old Oct 27, 2022 | 02:19 PM
'71 Pinto
Yes as I suggested in my previous post.
Old Oct 27, 2022 | 02:40 PM
VII's Avatar
VII
So this was about your suspension mode I guess? If so disregard all I have said so far as I thought this was about transmission mode.
