S-Class (W222) 2014-2020
What's Missing From My Trunk?
Old Oct 12, 2022 | 10:06 AM
BlackTuna's Avatar
2015 S550
As the title says... Pre-owned car that seems to be missing a piece or two from the well in the trunk. Can anyone tell me what is supposed to be in the foam cutouts on the right side of this photo?
(also, does anyone know if the 17mm socket comes with the car or not? Getting added to the bucket of 17mm sockets either way...)
Old Oct 12, 2022 | 12:24 PM
aeggroup's Avatar
2025 Range Rover, 2022 BMW M850 , 2017 MB E400 Coupe
I got my 2020 used as CPO and the trunk looks exactly the same minus 17mm socket.
Old Oct 12, 2022 | 12:31 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
My car came with a pair of small, zippered, yellow-fabric cylinders with Mercedes logos. Not sure what they're for ...
Old Oct 12, 2022 | 02:15 PM
blackbullit's Avatar
2013 ML350, 2019 S560
Remaining spaces are for Tire Fit repair kit with air pump. Your car probably came with run flats, in which case no Tire Fit is supplied. It is only for those with non run flats.
Old Oct 12, 2022 | 06:51 PM
Sactownmb's Avatar
MY 18 S450V RWD Diamond White
Yellow safety vests. When it’s dark or overcast & you need to change a tire or ? 😎
Old Oct 13, 2022 | 12:36 PM
Quenthel's Avatar
S560 Long 4Matic (DE) MY 2018
Here you're obligated to have both the first aid kit and the vests IN THE CABIN. Not the trunk, but the inside the cabin, and if you need to wear a vest, you must wear it before you get out of the car.
Thankfully, the warning triangle is where it should be ​​​​​​.
Old Oct 16, 2022 | 01:49 AM
ebceksl's Avatar
Mercedes S 500 4MATIC W222 (2015)
I have a repair kit and a air pump in my trunk. See pic.
Old Oct 16, 2022 | 01:51 AM
ebceksl's Avatar
Old Oct 16, 2022 | 01:53 AM
ebceksl's Avatar
My first aid kit.
Old Oct 16, 2022 | 07:46 PM
FYI - This is the Tire Fit kit.
Old Oct 23, 2022 | 12:24 PM
BlackTuna's Avatar
2015 S550
Thank you all for the pictures and information!
Old Oct 23, 2022 | 02:19 PM
Did USA cars come with a first aid kit?
