Caliper Piston Stuck Out
Hello all. Today, I started changing my rear brakes. I put the system in the "fitting position" under the service menu & then took the caliper off. When I did, the piston extended fully... Once it did that, the screen went to "currently unavailable". There is no pressure/fluid in the piston, yet it will not retract under pressure. Any idea what to do? It cannot fit back over the old brake pads. Is there a way to trick the system into the fitting position? Perhaps my caliper is bad?
Edit: Went to the C43 forum and this is pretty common. Dealers have said faulty caliper. I don't believe so. A guy used a big C Clamp to push it back.
