S-Class (W222) 2014-2020
Surprise Dashboard Warnings
Old Mar 20, 2023 | 01:09 PM
jlewis108's Avatar
2015 S550
I posted this on the S63 forum:
​​​​​​I have a 2020 S63 with 30k and no issues until yesterday. When I started up, 3 warnings popped up on the dash screen.
Active Brake Assist Functions Limited
Active Lane Keeping Assist Inoperative
Active Blind Spot Warning Inoperative
The car has had no issues in the 2 years since new. I have an appointment with the dealer, but would appreciate any advice. Bad sensor? Weak battery? Software?
Old Mar 20, 2023 | 01:37 PM
vinflouen's Avatar
2019 W222 S560 4Matic/2025 Yukon Denali
Probably frost on sensors
Old Mar 20, 2023 | 02:44 PM
jlewis108's Avatar
2015 S550
It's been sunny, mid-50s in South Carolina. Made sure that the sensors are clean.
Old Mar 20, 2023 | 03:03 PM
MBGuy2022's Avatar
2019 S560 4MATIC Sedan
Probably a bad sensor in one of the bumpers or camera behind the inside mirror since it came on when the vehicle was started.
Old Mar 20, 2023 | 03:15 PM
S_W222's Avatar
Current/Last 5-years:GLS;G70;Alpina B8;X7;Accord. Sold:X7,TeslaS;S560;S550,X5;530e;L.Navigator;LS460
When I see (multiple warnings), I usually get optimistic that it maybe related to one (single) isolated sensor issue.
Old Mar 20, 2023 | 04:29 PM
Grandpa Bee's Avatar
2014 S550 4Matic, 2015 ML400 4Matic, 2019 E450 4Matic Wagon
I had those issues on my 2014 S550 and it turned out to be a weak auxiliary battery. Replaced the battery and the warnings went away.
Old Mar 20, 2023 | 06:14 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
Definitely low voltage issues when they all come on sumultaneously.
Old Mar 20, 2023 | 08:51 PM
bishop64's Avatar
2021 S450 4Matic
Check the tyre pressures. Adjust if necessary. Reset them as 'reference value', if these warnings do not go away even after pressure adjustment.
Old Mar 21, 2023 | 08:26 PM
Denis Osullivan's Avatar
2018 s560v4
This happened on my car. Xentry showed it was a bad sensor module in the rear bumper.
Old Feb 3, 2024 | 08:15 PM
Joshua's Avatar
Hello Dennis, can you help please.
What did they mean by a "bad sensor Module in the rear bumper".
I have an S560 (In Australia) and recently had 3 warnings after someone bumped my rear bumper corner in a car park. Quite a hard bum looking at the damage on their car compared to just paint scratches on mine).
Did you mean a sensor (as in rear parking sensor) or was it the rectangular radar control module that connects to the actual 4 sensors on the back bumper ?
Old Feb 3, 2024 | 08:42 PM
2018 s560v4
[QUOTE=Joshua;8918341]Hello Dennis, can you help please.
Thanks[/QUOTE
It’s the modular that’s in the bumper. It’s held in there in a bracket that seems to be brittle and breaks and creates the module to move and shift.
The dealer changed the modular but still had the messages. Then they took the bumper off the second time and duct taped the module to the bumper to make a more secure fit.
My guess is that the modular is no longer making good contact with the bumper.
Good Luck.
Old Feb 3, 2024 | 09:50 PM
Joshua's Avatar
[QUOTE=Denis Osullivan;8918352]
Thanks[/QUOTE
Good Luck.
thank you for the quick response.
i believe you may be right.
my car did have a knock in a car park at the passenger rear bumper corner.
it helps me narrow things down.
much appreciated and I will circle back with what my solutions turns out to be.
