Rough shifting 2015 w222
I don't notice it much when I drive it besides on certain inclines and certain stop and go. For me it does not happen all the time. My wife said it gets worse on some days and often it will go away for a bit.
There seems to be a bunch of information about a handful software updates, custom software updates where the diagnostic computer is used while driving/shifting. I was also thinking of doing another transmission service.
Let me know your all thoughts?
Could be anything from Adaptation to Trans plate to Updates in order to fix
Xentry would clearly show what is wrong
If you want to maintain or at least check before bring it anywhere for a fix so you don't get ripped off
feel free to visit our website and request info
We do updates too
I have already posted about this in a very popular and well known thread (link below) nearly 4 years ago, in 2019!. Several forum members here tried it, printed my service record in that thread, went back to the dealer and got the problem fixed. I can save you the time instead of reading all the 7 pages and 166 comments --> read post #1, post #64, post #105, post #108 and #129.
https://mbworld.org/forums/s-class-w222/760220-finally-fixed-common-transmission-rough-up-down-shifting-w222.html
I know folks have replaced transmissions, flushed transmission, replaced transmission internal transmission components, updates... all without improving this condition. 9 out of 10, it is not a mechanical issue but rather a torque calculations between the ECM and the transmission. The statement is known by Cory Sarver, Sergio, Germany that have fought through this technical issue including back and forth finger pointing between German transmission vs engine engineers. Forum member MichaelinATL can tell you more about that (he also followed the same process and reported success). Even Force Adaptation may not fix this problem, but most those who tried Force Adaptation ended up with great results including myself. A few members and myself here used to form a group exchanging test messages all together, helping each other, and most of us were successful in getting what we needed done by our dealers. I still get thanks notes from time to time in private messages on the forum here for that post.
Back in 2020, there were some discussions about a solution that MBenz is developing but it requires repeating their emissions certification application process. Ask your dealer if this has been done (but again, Force Adaptation will hopefully fix this issue anyway).
Also, printer this paper and present it to them. Good luck : ) --> Software update alone is not enough, as indicated above, ask for the Force Adaptation as well.
Thank you for repeating but there is no such thing as "force adaptation" that does not exist, it never existed.
Feel free to sign up to the club to get some lessons. that's is what the club is about. ask for "Force lessons"
but replacing the trans plate remains commun
Second, This is all coming from one of the most reputable resources in this forum, @Konigstiger, serving this great community for free since 2003:
Konigstiger: {“..speak with shop foreman, who will should normally check for upgrades, and request "forced adaptation"..”}
Third here is a part of an email that a service advisor in a Mercedes dealer forwarded to one of our members here in this forum: "The low value of 11.5 is actually good comparatively speaking regarding other like models. If this client insists that we do a forced adaptation the results are typically that the 11.5 value will trend to 15.0 to 17.0."
Last, and as a courtesy and since you highlighted a part of my response “as indicated above”, I want to clarify: The sentence "as indicated above" is meant to be a leading sentence to the subsequent sentence "ask for the Force Adaptation as well." The sentence "Software update alone is not enough" was only the first part of a 3-part english sentence, and the sentence "as indicated above" is a leading sentence referring to the following 3rd part, which is my own sentence also above "ask for the Force Adaptation as well.". Hence, the "as indicated above" does not refer to your comment. It's still up to you, however, to understand which part of the sentence the phrase "as indicated above" is referring to, it won't matter for me. I didn't even bother to read your response, so there was no need for you to jump in and accuse me of referring to yours.
If the term forced adaptation is a term used in the service department or in documentation referring to a task, then it is valid.
Nobody should care if this an Xentry term or not…
There's definitely a limit to how much I and others will pay to improve their transmission behavior ...
What is likely needed is the forced "manual" adaptation. Reset might work, but for most folks it worked for a few days or a few 100s of miles, and transmission will again start doing hard downshifting later at some point. This was already reported by many others as well as me in the original thread. A few of us reported success when we first got the car after a quick reset, and came back with same issues later.
- From my post on Old 10-24-2019, 06:30 PM, post #7 below: No, it's not a transmission reset. We tried that last week and didn't work. link: https://mbworld.org/forums/s-class-w...ting-w222.html
- Another forum report around that time: "I hope they didnt just do a transmission reset and that problem will recur shortly." It was a well-known issue we all tried at that time. Reset did not work for most of us for more than a days or 100s of miles. Once the transmission re-learned the same previous values, issue comes back. Another comment: "A ((""MANUAL") shifting normalization. The trick according to him was not to allow the software to just automatically chose the new shift points, but to "MANUALLY" adjust them while driving the car around and adjust them for values that the software has chosen based on his judgement on where they need to be to make shifting smoother for my case.".
Note: I think it is not a bad idea to at least try the quick transmission reset yourself, nothing to lose. I don not know if these steps will work on a W222 and am not claiming they will, but this article says it will, and it can be useful so u can do it yourself if you chose to. If the quick reset does not work, you will need the force adaptation for sure.
DIY Reset Transmission Adaptive Shifting – How to Programming Instructions DIY: https://www.mercedesmedic.com/reset-...-instructions/
No kidding, I would know we have such "member" I'm starting to debate if I should get rid of my Mercedes dealer and use you.... man....you are really modest !
