S-Class (W222) 2014-2020
What makes a good service history?
Old Jul 21, 2023 | 12:45 AM
Colliot's Avatar
S
One of the vehicles I'm looking at has ~15 service history. But what is weird is that "90,000 mile service performed" is performed at 5000-ish and 13000-ish miles.
  • Maintenance inspection completed
  • 90,000 mile service performed
  • Battery/charging system checked
  • Fluids checked
  • Brake fluid checked
  • Brakes checked
  • Antifreeze/coolant checked
  • Drive belts checked
  • Drive belt(s) replaced
  • Exterior lights checked
  • Lights checked
  • Hood adjusted
  • Horns checked
  • Tire condition and pressure checked
  • Wipers/washers checked
  • Headlights serviced
  • Engine oil/fluid leak checked
  • Drivetrain checked
  • Steering/suspension checked
  • Vehicle washed/detailed
  • Oil and filter changed
  • Maintenance reminder reset
  • Tires rotated
  • Tire pressure monitoring system reset
Another one has no service history.
They are all around 20000-ish miles. I wonder what problem the service history for these two vehicles may imply?
Old Jul 21, 2023 | 07:32 AM
Mason.Safari's Avatar
EQB250
I am also considering to buy one 2017 S500 ( I think equivalent S550 in US) and had 5 services ...
Service 5 14.03.2023
Service 4 13.04.2022
Service 3 27.05.2021
Service 2 08.02.2021
Service 1 03.01.2020
... first one almost 3 years after registration on 22137 km ... is it not too late or could be normal ? also other strange was that on 08.02.2021 they had services and then 3-4 months after that they had another service on 27.05.2021 and they serviced the transmission ...then 11 months later on 13.04.2022 , another MB rep did same thing and services the transmission ( Automatic transmission: oil and
filter change) ... isnt it strange... I spoke with both MB rep and they didnt have nay explanation and today the mechanic advised all good with transmission ?? the report is attached : should I be worry ( in the details last service, not attached here nothing was recommended only replacing the front brake pads and no mentioning of the transmission...
File Type: pdf
