Night Vision Camera Replacement
FWIW I can get that camera for $3600.00 + tax. New. Have Peter calibrate.
Camera in my car suffered a similar fate as yours.
Was expecting it not to work and it did not right after install but a couple of days later when I clicked the button it just worked so I never went for calibration. Detection and spotlight seem to operate normally but since this is a useless feature to begin with I just might not be able to tell it's misaligned.
Can some explain in some detailed way about an aftermarket system that works like the factory night vision?
Grille heat sensitive camera - $5k
Windshield IR camera - $1k
IR Headlights - $5k
Wiring - $500
The button - $100
(should also retrofit the camera washer element not that is works for anything)
Most cost effective retrofit is to remove the car and install a new one fitted with NV.
