Multi contour seats not working.
Hi all. First post here. I have a 2015 w222 s550. The multi contour seats are not working. No massage, auto bolsters, lumbar. Dealer says it’s the Actuator Assembly part number 222-800-21-00. This is in the seat. Assuming the drivers seat. Does anyone have experience with replacing this? Can it be done on your own? I also assume it’s called something else because I can not find any info from anyone about It with this name.
2020 S450 4Matic, 2022 GLS450 4Matic, 2015 C300
Damn, that's not a cheap part to buy, let alone replace. I'm sure that getting the info to replace it won't be an issue, there are usually a couple of clips that you need to be careful with when removing seat backs.
From that link:
Shop around, I'm sure you can find it cheaper: https://www.mercedesbenz.parts/oem-p...ock-2228002100.
eBay brings back some used parts for a reasonable price: https://www.ebay.com/sch/i.html?_fro...2100&_osacat=0
From that link:
- SKU:222-800-21-00
- Other Names:Valve Assembly, Valve Block
