Is this behavior of lane keeping assist normal?
When I keep the lane keeping assist turned on it behaves:
1) When I go over the line, I hear some 3 TOOOK sounds in steering wheel with just small bump, i dont feel any vibration
In CLS C257, 2018 I can feel strong vibration acroos the whole steering wheel and wheel even turns automatically in oposite direction.
Is behaviour described in 1) normal for W222 facelift or I am missing something in settings or malfunction?
No error codes on diagnostic tool
If I go over the line the car pulls hard to the other way by putting on the brakes on just one side of the car. Steering wheel yanks to the opposite side of the hwy line.
On your front grill, do you have the full height sensor plate or half? If half, you might not have the steer adjust option.
Joe
Anyways, I don’t know if the vibration motor is just too weak or broken? My 2014 E350 would make the same sounds but I would feel the vibration in the wheel. This S550 makes the same sound but I can barely feel the steering wheel shake if it shakes at all. But I’ve been so accustomed to the vibration warning in the E350 that I don’t even notice it anymore. So I especially don’t notice it anymore in the S Class. It’s only when someone else drives my car and it happens and they’ll say “what was that?” that I remember that feature still exists.
I don’t know for sure if it is designed that way, or maybe both of ours are broken. The only reason I say that is because the E Class I had, you can definitely feel it and it makes sense that you do. It’s suppose to alert you and warn you that you’re about to go over the lines. So it doesn’t make sense that in the S Class, you don’t feel it. Especially if you have music on, you won’t even know it’s warning you.
