S-Class (W222) 2014-2020
main battery replacement
Old Sep 18, 2023 | 08:20 PM
Merserybenze's Avatar
2022 AMG GT 53, 2020 Sl450. Did drive 2018 S450
After 6 years mine finally started giving me messages on the dash 'pull over and keep the engine running'. Figured it was main battery as i'd already replaced the aux a year ago. Dealer wanted almost $500 just for the part. Found an equivalent for less than $300. Took 15 mins. No coding or error messages generated.
https://shop.advanceautoparts.com/p/...agm/10866724-P
Old Sep 18, 2023 | 09:33 PM
retatt's Avatar
Veteran: Army
My go to for service dealer replaced mine under warranty after several complaints to another dealer about a partially charged batttery on the Mercedes Me app. Surprised to hear the battery was so expensive. I guess it was worth the additional wait time at my B service.
Old Sep 19, 2023 | 11:09 PM
2012 merc amg's Avatar
2018 S560
Walmart sells them under 200 dollars and installs them.
Old Sep 20, 2023 | 12:00 AM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
I'm on original from 2014, no issues. 9 Years... Going on 10. I use CTEC Charger During Winter and if car is not used often. I drive it less than 9K a year. Its on the 2nd AUX battery.
Old Sep 20, 2023 | 12:22 AM
BenzV12's Avatar
W212 FL
You did a good job replacing the battery . Dealer price can be more expensive than 3rd party stores which is very normal to me .
Old Oct 17, 2023 | 10:21 AM
latif pro's Avatar
s-class w222
I replaced it directly with a 95 amp Varta type, made in Germany (AGM).
Old Oct 18, 2023 | 03:24 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
Going on a year on my WalMart AGM battery for $169. Only thing I still wonder about ... there's a setting in the car's electronics where you tell it you've changed the battery. Would cost almost as much as the battery to have someone connect Xentry and reset it, so I decided not to and see if the car can figure it out on its own. So far, all seems fine ...
Old Oct 19, 2023 | 12:19 AM
Nice Ride's Avatar
Is this a good deal?
Genuine Mercedes-Benz Starter Battery Primary (2007-2023) OE 0019828108 | eBay
Old Oct 19, 2023 | 09:18 AM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
Originally Posted by Nice Ride
I have not seen a Mercedes branded version of this battery for less, especially considering they are shipping it for free?! Must be overstock. I would check the date code on the terminal, might be older stock and perhaps not worth the trouble.
Old Oct 19, 2023 | 11:16 AM
MBenz07's Avatar
2019 S560
Just replaced my main battery, pretty straight forward and took less than 30 min. I took my time, didn't want to damage anything and could have swapped battery in 10 min. All came back including settings, the battery in the car was 2019 so trickle charger was always on when I parked. Car always started but I didn't want any issues as I'm planning a roadtrip to Florida (Texas) next month and want to make sure all systems are 100%.
Old Dec 14, 2023 | 12:50 PM
Robb92914's Avatar
S560, GLS63
which battery did you go with?
Old Dec 30, 2023 | 08:07 AM
ebceksl's Avatar
Mercedes S 500 4MATIC W222 (2015)
I¨m checking faylt codes now and then on my car.
After reciving those 2 fault codes for a while (no sign on dashboard) i decided to replace starter battery (Varta Silver 105AH AGM)
B1F4500 Stored The resistance of the starter battery is too high.
B21059A Current and Stored The capacity of the starter battery is too low. The operating conditions for the system or the component are not met.
Old Jan 18, 2024 | 05:53 PM
MayorMcCheese's Avatar
Forums Most Modified W222
Any issues when you had replaced the battery? - any pop ups or anything since installing it? did you connect anything to the terminals in the engine bay to keep the power while swapping in the trunk?
Old Jan 20, 2024 | 03:55 AM
ebceksl's Avatar
No problem. Removed/installed the battery according to mercedes instructions. No battery backup connected during this time. No memory settings in the car were lost. Connected diagnostic equipment after to check/remove any error codes.
