Noise in front suspension, low speed bumps.
Hey guys....
Information for when your 222 car gets enough miles on it to start making noises in front suspension that sounds much as my 221 car did with noisy bushings at the top of ABC struts.....
Front upper control arm bushings worn enough to make noise... but never a clunk or tire wear!
Upper control arms are easy enough to replace... though this would have been less onerous had MB used captive nuts on the ends of bolts that are hidden under a tangle of all wiring at the right front.
Worth noting.... Bushings at top of ABC struts are a much improved design compared with what we had in 220 and 221 cars.
I was there to replace the upper control arm and glad to see the improved design of the ABC strut.
Peek in there with the car on tip-toes. You’ll see the bushing I’m referring to. Nice big one.
