S-Class (W222) 2014-2020
P0133 Oxygen Sensor
Old Feb 12, 2024 | 03:23 PM
jayrawk's Avatar
ML 500
P0133 Oxygen Sensor
Hello,
I got check engine light, did diagnostics and came back P0133 Bank 1 Sensor 1, I'm reading, Bank 1 Sensor 1 means Upstream Right/Rear; having trouble figuring out what part it is, I'm seeing these two but not 100% sure: Part Number: 009-542-60-18 and Part Number: 008-542-78-18, any help would be appreciated.
Also, will Bosch brand work fine for this or should I get the OEM from the dealership?
Old Feb 13, 2024 | 07:43 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
Not sure your model or year, but Rock Auto shows the downstream and upstream sensors for a 2016 S550 here ... https://www.rockauto.com/en/catalog/...2)+sensor,5132
The Bosch upstream sensor line item references "OEM / Interchange Numbers: 0095425918, 0095426018". 'Upstream' of course means before the catalyst.
I don't always buy stuff from RA, but their catalog info seems pretty reliable for the things I've needed.
Old Feb 14, 2024 | 02:12 AM
jayrawk's Avatar
ML 500
Thanks, I have a 2014 s550 base model. I'll take a look at RA.
Old Feb 16, 2024 | 05:30 PM
jayrawk's Avatar
ML 500
I found this part which looks to be correct: https://www.rmeuropean.com/Products/...14-V13058.aspx
It does say Position Upstream Left, Upstream Right, does w222 use the same o2 for both left and right upstream?
