S-Class (W222) 2014-2020
Engine oil level check inoperative
Old Mar 18, 2024 | 01:26 AM
brl12's Avatar
S550
Anyone else get this message when trying to access the oil level check feature?
I've let the engine cool. I tried to perform the check before starting the car. Nothing seems to work.
Old Mar 18, 2024 | 08:47 AM
NbyNW's Avatar
Veteran: Navy
Various
See pg 411 in your manual or thereabout, not sure what model you have.
For the onboard computer check it needs to be warm/normal temp, at idle, and on a level surface.
It also measures it while driving and can take up to 30 min.
Old Mar 18, 2024 | 04:23 PM
blackbullit's Avatar
2013 ML350, 2019 S560
You can also check oil level through the workshop window. This is accessed through Assyst plus where service reset is performed.
Old Mar 18, 2024 | 04:42 PM
brl12's Avatar
S550
That didn't work either
Old Mar 18, 2024 | 04:43 PM
brl12's Avatar
S550
That's where I'm having the issue
Old Mar 18, 2024 | 07:54 PM
NbyNW's Avatar
Veteran: Navy
Various
I have found it takes time. Check it after a drive. Let it idle, etc.
If no luck maybe time for a dealer or indy shop visit. Sure a service rep would be glad to check it.
Old Mar 18, 2024 | 10:43 PM
SilberGrau57's Avatar
2004 W240 Maybach 57
I know this is going to sound like heresy, but I wouldn't worry about it until the idiot light comes on telling you you're one quart low, and then add 1 qt! Keep a quart in the trunk for peace of mind. If M-B really wanted you to be able to check the oil level, they'd have installed a dipstick.
