S-Class (W222) 2014-2020
Coolant levels full but warning light says low - thoughts?
Old May 5, 2024 | 03:51 PM
Donnymac's Avatar
63 Falcon vert
Coolant levels visually full but warning light says low - thoughts?
Runs at 190/200*.
Bad sensor? Easy swap?
Thanks.
Old May 5, 2024 | 08:42 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
Sensor or reservoir, start with sensor but it's likely the reservoir.
Old May 5, 2024 | 10:08 PM
Donnymac's Avatar
63 Falcon vert
Reservoir as in leak? Visually both are at full level.
With two reservoirs, one is for turbos and one the motor? I should know this.
Old May 5, 2024 | 10:10 PM
VII's Avatar
VII
The reservoir contains the answer to how that sensor that does not get wet can tell the level.
Old May 5, 2024 | 10:16 PM
Donnymac's Avatar
63 Falcon vert
Got it.
Hope you survived all the rain and ducked the twisters.
Old May 6, 2024 | 10:44 PM
VII's Avatar
VII
Thanks, luckily it has not been too bad over here but the season is still young.
Old May 6, 2024 | 11:38 PM
S550e's Avatar
W222 S550e, C207 E550, W212 E350
Had this issue and my reservoir had a slight leak. Replaced and the message is gone. Also, be sure to check your intercooler reservoir (in the middle under the engine cover) once in a while... recently learned that there is not a sensor for that tank.
Old May 7, 2024 | 12:01 AM
Donnymac's Avatar
63 Falcon vert
Thank you sir. Will check mañana.
Old Sep 1, 2024 | 07:13 PM
motojazz's Avatar
2020 GLC
I have this issues as well, the coolant level warning lights on after 65km city drive, the engine oil temperature is around 98, i don't know why, is the mecedes quality like that
Old Sep 2, 2024 | 12:21 AM
Donnymac's Avatar
63 Falcon vert
There are 2 coolant tanks. I intentionally slightly overfilled and no more warnings.
other option is failing sensor. Mine never overheated or put water on the garage floor.
I also cleaned both pressure caps/necks.
Old Sep 2, 2024 | 01:16 AM
VII's Avatar
VII
The other part of the sensor is in the tank, for recurring issues change the tank.
Old Sep 2, 2024 | 03:30 AM
motojazz's Avatar
2020 GLC
anyone can share some pics to indicate how to take the coolant sensor off?
Old Sep 4, 2024 | 11:30 AM
VII's Avatar
VII
The disconnect is right there on top but the actual sensor is in the tank
