S-Class (W222) 2014-2020
Coolant going to windshield fluid
Old May 6, 2024 | 12:29 PM
jayrawk's Avatar
ML 500
Hey guys, I noticed I was losing coolant and had no leaks. Recently I was thinking it’s coming from my washer fluid, when I used the windshield I can see some coolant stains.
what I did was drain my washer fluid and refilled my coolant reservoir and exactly what I thought, after a short drive it filled the washer fluid reservoir. I believe it’s the heating element I need to replace but anybody know if this can be fixed without replacing the whole unit?
I believe this is the part?
https://www.mbpartsource.com/oem-parts/mercedes-benz-heater-element-222830006164?c=Zz1lbGVjdHJpY2FsJnM9d2lwZXJzJmw9MSZ uPVNlYXJjaCBSZXN1bHRzJmE9bWVyY2VkZXMtYmVueiZvPXM1N TAmeT0yMDE0JnQ9YmFzZSZlPTQtN2wtdjgtZ2Fz
thanks a lot!
Old May 6, 2024 | 03:27 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
Yes, the heating element in the washer reservoir can easily be changed with just a little wiggling and jiggiling to get it up and out of the tank.
IIRC, there are just hose clamps on the element atop the cap.
Old May 6, 2024 | 04:40 PM
jayrawk's Avatar
ML 500
Thanks, Tom! I just ordered the OEM part from AutoHausaz, should arrive in a day or 2. Looks like the center screw was loose and coolant was squirting out of it and I also noticed a crack (circled in blue pic below). Hopefully this solves the problem, I don't see the coolant getting there any other way except for the heating element.
Does the heating element function and heat up the windshield washer reservoir fluid even when I don't use the wipers?
Old May 6, 2024 | 04:46 PM
Yes, engine coolant going through that element heats the windshield washer fluid.
Old May 7, 2024 | 09:33 AM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
Would recommend coolant flush (is your coolant not red?) and coolant reservoir replacement to go back to 15yr interval.
Old May 9, 2024 | 11:25 PM
jayrawk's Avatar
ML 500
Yeah for my model w222 2014, the dealer puts blue coolant not the red one (not sure why but I have seen 2015 and up with red). The filter is different too, its the full skinny cylinder shape vs the shorter thick filter with triangle part sticking out.
