Need help please for code P0234
anyone had experience about or any solution advice thank you so much
is your car tuned?
did you check to see if the connecting rods to the wastegate are detached? Lift off the engine cover and in the middle top you will see 2 rods.
check to see if they are attached.
it seems like a mechanical issue with wastegate not opening and making turbos spin too hard/fast.
is your car tuned?
