S-Class (W222) 2014-2020
Coolant
Old Jul 3, 2024 | 02:22 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
Coolant
Hello guys,
My S450 pop up some message to add coolant. Which coolant do you guys recommend ?
There are 2 coolant reservoir. One for engine/radiator and one for turbos. Can I use the same coolant ?
Thanks.
Old Jul 3, 2024 | 04:11 PM
vincheung's Avatar
S63, GLE580, BV250
Same coolant for both, I use the MB branded coolant which requires it to be mixed 50/50 with water. Other brands like Zerex and Peak are perfectly fine to use also just check the labels for "Mercedes." The center reservoir doesn't give off messages when low I believe, so it may be the main res thats reading low. I've removed my engine cover and never put it back on to make my periodic fluid checks easier.
Old Jul 4, 2024 | 06:59 AM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
When my system needed a few ounces, I just added distilled water.
Old May 7, 2025 | 04:49 PM
sleepings's Avatar
W205
Hey all!
Is the transmission cooler fluid the same as the engine one?
EDIT: Sorry, I just saw the second comment that they are the same!
Old May 9, 2025 | 04:36 PM
Badgertastic's Avatar
S550e
Originally Posted by sleepings
Hey all!
Originally Posted by CharlyE500
Hello guys,
Thanks.
On the W222 S550, the main coolant circuit takes care of the engine and transmission. There's a secondary circuit for the turbos, and on the hybrids, there's a another one for the battery, and they're all independent with their own separate reservoirs.
The main reservoir for the engine/trans is under the passenger side panel, the turbo one is under the engine beauty cover, and the hybrid is under the driver side panel.
They all use the same MB Pink coolant.
Hope that helps!
Old May 11, 2025 | 11:50 AM
waterzap99's Avatar
S550 V8, CL600 V12, SLK32 AMG
This is a good Mercedes Coolant article. Just search for it....
Choosing The Proper Engine Coolant For Your Mercedes from FCP Euro
Old May 11, 2025 | 12:16 PM
W205C43PFL's Avatar
Thank you, linking it as well: https://www.fcpeuro.com/blog/engine-...-your-mercedes
Old May 11, 2025 | 01:25 PM
streborx's Avatar
Top Answer: 1
G550
I use Zerex G40 (pink cap) that comes 50/50 pre-mixed -- about $20/gal jug.
