S-Class (W222) 2014-2020
W222 S500/550 vibration
Old Aug 28, 2024 | 04:57 PM
oguzhan99's Avatar
Mercedes S 500 Uzun 4 Matic
Hello everyone, I have a 2014 model S 500 4 matic. While driving, I feel a vibration in the car and steering wheel when I lightly press the gas pedal between 1000-2000 rpm. It decreases at high rpm. What do you think could be the reason? (106,000 km/ 65,800 miles)
Old Aug 28, 2024 | 07:00 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
Vague internet guess says engine mount.
Old Aug 28, 2024 | 11:24 PM
95Sinned420's Avatar
2016 S550
If it varies with RPM, no matter what speed, I would also say motor mounts. Do you feel a significant change in vibration while idling and revving the engine a bit? Or changes in vibration when you go from Park/Neutral to Drive/Reverse?
Old Aug 29, 2024 | 08:00 AM
oguzhan99's Avatar
There is no vibration when I rev it from idle. It only exists when I press the gas slowly at low rpm while cruising. There is a small momentary knock between P N D R transitions. Engine mount comes to my mind. But I thought that if the engine mount was faulty, the same vibration should occur when I accelerated while idling. By the way, the transmission mount was also recently changed, but the vibration did not go away
