S-Class (W222) 2014-2020
Self Maintenance On an S Class
Old May 19, 2025 | 10:19 AM
ChilledFaith's Avatar
Hi All,
I'm new to the forums, but been trying to find a 2016-2017 S class in the spec I'm looking for for the last two months. Not in a rush, so I'll get there eventually, but once I do, I have a question.
What do you all do to keep the longevity of the vehicle? I understand to bring it in for regular maintenance, but that is about all I see on taking care of this car. But on my BMW I would throw in a bottle of seafoam every once and a while. Get tires rotated (or checked) frequently, minor things like that. So what "minor" things are good best practices for this vehicle that may not be obvious?
Old May 19, 2025 | 11:11 AM
UltraSpeed's Avatar
GLS450 S550
Hi!
Self maintenance only or also self repairs?
Old May 19, 2025 | 11:43 AM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
Change oil around 50% of recommendations, run a bottle of Techron through gas tank at each oil change, repair small problems promptly- before they become big problems.
My 222 has been perfect since purchase.
Old May 19, 2025 | 06:52 PM
W205C43PFL's Avatar
Originally Posted by ChilledFaith
Hi All,
When buying the used vehicle, get a PPI (Pre-Purchase inspection).
The usual stuff, all mounts, condition of sparkplugs, injectors, camshaft adjusters, brake fluid, power steering fluid (if applicable), coolant, transmission fluid, front diff fluid, rear diff fluid, transfer case (the 3 mentioned, if 4MATIC otherwise just rear diff fluid), driveshaft hangers, engine and transmission mounts, alignment, wheel balancing, tires, brake pads, brake rotors, check condition of coils, oil change (analysis via Blackstone labs?, same goes with all the fluids)?, if equipped, airmatic system condition, 12v battery condition, aux battery condition, check timing chain, all belts and pulleys, check to make sure there is no oil in wiring harness (a common issue on certain MB engines that can get into the ECU, destroying it). I will add if I remember more.
Old May 19, 2025 | 06:53 PM
W205C43PFL's Avatar
You could also follow this CPO checklist that MB uses when they CPO a vehicle but it doesn't cover all the items aforementioned https://www.mbusa.com/content/dam/mb...s-Brochure.pdf
Old May 19, 2025 | 09:16 PM
JettaRed's Avatar
Veteran: Army
Quite the buzz-kill! He's probably gonna go get a Honda (just not the 1.5L turbo).
Old May 19, 2025 | 09:21 PM
JettaRed's Avatar
Veteran: Army
I have a question...
Do you plan on doing your own work or have a shop do everything for you? Regardless, every MB owner should have a proper scan and diagnostic tool, namely XENTRY. Best place to get what you need, plus Level 5 diagnostic support, is through the BenzNinja Club. Check the banner at the top of the page.
Old May 19, 2025 | 10:34 PM
W205C43PFL's Avatar
Good preventative maintenance though : )
Old May 21, 2025 | 04:47 PM
rebounder63's Avatar
2016 S550 4Matic Selenite grey
Smile
Hi All,
Keeping your S Class in peak condition is not that hard. There are a lot of videos on U-Tube showing how to change brakes, service codes, batteries, filters etc. Keep a record or spread sheet to record the different types of services recommended, needed and completed. On every other oil change I use Liqui Moly engine cleaner, and motor oil. Change or check the air filters on a regular basis. Having the right tools also helps.
