Hydroplaning like crazy - 1yr old Continental DWS06 - DO NOT BUY THESE TIRES
I am ready to swap them out ASAP, so would appreciate any recommendations for a safe, quiet, all-season tire. My local Costco carries Firestone Firehawk AS V2, Bridgestone Potenza Sport AS, Turanza Everdrive, Michelin Primacy Tour A/S, Pilot Sport AS4, and BF Goodrich Advantage Control.
Technically it's the same with every tire, but the DWS tells you exactly. As tires wear, wet performance goes to nil as the tire can't evacuate enough water anymore and starts aquaplaning.
FWIW, in the climate that I live, mostly dry and not very cold in the winter I have summer performance tires on my car for the entire year. One reason for that is with the kind of driving I do, my tires at times reach temperatures above the peak for AS tires >130F. I just went onto one of my favorite canyon drives last weekend and my front tires went as high as 170F, so that's no longer AS tire territory. I'm not saying your tires may get as hot, but just making the point that temperature is probably the biggest factor when it comes to tire performance. Make sure the tires are optimized for the temperatures you put them through. I'm generally a Michelin guy, and the only tire I've ever aquaplaned with was the Pirelli P Zero, partly because it got worn down over the summer and didn't have enough tread depth left when the rainy season started. After that I put on a new set every year at the beginning of the rainy season. That worked out, because I pretty much went through a set of tires in one year. It's similar with my current car, which is lighter than yours, but I likely drive it harder than you do your S560. My front tires are done after about 8k miles and the rears after about 12k miles.
I put the CrossClimate 2 on my wife's car. The CC2 is a touring tire, and is the perfect tire for her car. It doesn't need the high performance that I demand from a tire for my car, but we occasionally drive up to Tahoe and the CC2 outperforms even some winter tires in the snow. The point is there is no wrong or right tire and advising not to buy a certain tire isn't all that helpful. One must choose a tire that fits the kind of driving they do and the climate they drive in and always keep an eye on the wear level. Mileage doesn't mean all that much and keep in mind that with staggered setups where you can't rotate the tires, the manufactures cut their tire warranties in half. For example Michelin's UHP warranty is typically 30k miles, but on a staggered setup it's only 15k miles. It's the same with other manufacturers.
Filling tires to their maximum recommended pressure will result in the best hydroplaning margin.
Of course, running tires at lower than max recommended, will result in a lower hydroplane margin.
I have experienced hydroplaning in the S, and although there was some standing water on the road, I was still surprised.
Having 245/275 section widths means you need to slow down when there is standing water. Before the S I had a BMW with 225/245, and this car skated as well.
My old 300TD ran 196/65 on all corners, and never once hydroplaned, even at highway speeds through standing water.
For over 15 years on them I've gone through 2 sets of rears for every set of fronts.
Welcome to the game.
GL
maw
I run the Michelin Pilot Sport 4 on an S class and an SL - and I'm very happy.
In Florida you don't need all season tires, you need Summer tires only year round.
Tread depth is most important to prevent hydroplaning.
The water need to be displaced and pushed out to sides of tire has to fit in the tread gaps and crevices as it works it way out...
The lower this volume (less tread depth) then the less water the tire can move and keep tires in contact with road.
The tread is designed to meet the water and start to move it away as the rest of the tire rolls thru and keep contact.
If it cannot pump enough water out of the way then the tire will ride up on this extra water and then you start to loose traction and we get hydroplaning.
so go check tread depth across tire width. if you have issues then maybe tires worn too much for amount of water on your roads.
I have same tires - albeit smaller and lighter MB and I have not hydroplaned - but I have before with the stock pro-conti it came with - but I also was not far from wear bars.
Nothing like getting your blood flowing then having your car's rear end start to slide out on interstate in rain after passing a bunch of 18 wheelers.
Whoa nelly (Kieth Jackson voice)
As someone above said - Next set of tires can be summer only tires but do check WET ratings on Tire Rack - I live in deep south and the heavy afternoon downpours are too often not to have proper tires.
GL
maw
Ironically, the only time I've unintentionally hydroplaned in a vehicle, it had contis under it. A bit of a larger tire than what the S takes, but still.
Is the OP's tire wear normal? Why???
https://teslamotorsclub.com/tmc/thre...photos.201532/
To be fair, I've seen bald tires in forums for everything I've owned with high torque. One difference is Teslas are the first powerful cars many people ever own.
It's also a good idea to have an alignment performed if you haven't done so recently.
