Owners in areas where snow is a thing,
Again, snow tires help. A lot. AWD helps even more when combined with snow tires. But when you're driving in extreme inclement weather like deep snow, you need ground clearance. When you're driving on a sheet of ice, at the very least, you need skill and snow tires. AWD (preferably something better than the 4matic - nothing wrong with 4Matic, but it's not amazing), and ideally a decent 4WD system come in even handier. At the end of the day, my goal is to get to my destination safely. If there is "lesser" vehicle is technically more capable at achieving that goal in severe inclement weather than say, my S, I'm using it, and the S can stay parked for a few months.
proper tires are always the only answer for any vehicle. Awd or 4wd is no good with bad/ inappropriate tires. As the saying goes, 4 x 0 equals 0.
W222 should at least be on par with the average AWD offering?
Heck, we're moving to a walkable city where the car will never be driven. I want to use the car specifically for winter trips up north
Honestly though I prefer an AWD sedan to an SUV in the snow as long as its not more than 5-6 inches. I have found when I have had both in the garage the lower center of gravity and lighter mass of the sedan makes getting around easier. The S Class gets surprisingly tall ground clearance in the suspension high mode, and if you are in really deep snow you can put it in transport mode up to 25 MPH and it gets REALLY high.
But for a while I had an AWD Lexus GS and then an AWD Lexus LS and a Grand Cherokee Overland with Quadra Drive and I preferred driving the Lexus sedans in the snow.
Obviously 10+ inches you need more ground clearance.
With 10" of unplowed snow, even the best SUVs with high ground clearance aren't getting around safely in that without chains. And chains present their own set of challenges.
I wouldn't drive it around like that normally, but in a pinch or if you get high sided or something then sure
Curious why they're calling it "transport mode". I suspect the additional height is to increase the break-over angle for loading onto some trailers?
Should have called it "Trailer Load Assist", (since MB seems to love calling everything "assist")?My car was in that mode because I had a flat and it was loaded onto a flatbed.
somebody who wants to drive across the golf course on the other hand is definitely going to need the ground clearance. I once had a Subaru that died and unfortunate death getting into a fight with a swing set on a playground in the snow.. the ground clearance was not an issue the non-moving swing set pole was.
Indeed, we have some of them fangled plow trucks here as well, but by the time they get to our neck of the woods, the snow is pretty much melted. The price you pay for living 25 miles from the closest paved road. Thankfully, people around here have snowmobiles and sno cats for when the snow gets horsy. But I'm not complaining about that. It's a choice we made to live here.
Between the choice of only RWD with snow tires and AWD with summer tires, RWD with snow tires hands down. Personally.
No argument there. Better to look cartoonish for a few minutes, than to be on display for hours until help arrives.
) and that RWD with snow tires will do even better.
Sing it....We are the wooooooorld.......
In the morning it was maybe 10ºF with 6+ inches of snow on the ground, traffic was running closer to 5MPH than 10 MPH (speed limit of 35 MPH) and traction was close to zero. Still I had to make it to Austin by the evening. I was on High Performance Summer tires at the time. I drove south on 285 to the intersection of 380 heading east at 10-ish MPH. I turned onto 380 and inched out of town slowly. After about 10 miles I was up to the dasterdly speed of maybe 20 MPH with a car in front of me going maybe 10 MPH. about 100 yards behind I gave the steering wheel the tiniest input I could and instantly felt the tires loose traction--
I have driven race cars on slick in 1" per hour rain at racing speeds, so I knew the only thing to do was to wait for the car to find traction again and hope this happened before the car hit anything. Yes, at this point you are merely a passenger--but as driver you can make the situation WORSE. Its a lot like flying an airplane--you HAVE TO keep the nose pointing forward at all times without fail and without inputting any control terms that would upset the vehicle. 10 seconds pass, then 20.....
--luckily, as the car slowly crossed the incoming lane, the front tires found some grip, so I straightened it out, and I passed the car. About 20 minutes later, the tires had had enough rotations with the cars 5,000 pound weight to get above freezing temperatures and traction improved steadily. I inched up into the 40MPH range than a bit faster, and by the time I got to the Texas border I was doing 55 MPH.
And all this was on tires that should not be driven in winter conditions--but I did not have a choice--and I DID have the skills to pull it off (barely).
{{Not recommended}}
