S-Class (W222) 2014-2020
Location of ambient temperature sensor
Old Jul 30, 2025 | 06:09 PM
brtuffli's Avatar
16 S550
My dash temp is showing constant 82° even though I know it’s 94° outside, so I’m assuming the sensor is bad. It also doesn’t go up when it’s been parked on a hot balcony parking lot for 30 minutes. Does anyone know where it’s located on my 2016 S550 sedan.
Old Jul 30, 2025 | 06:23 PM
Sathinas's Avatar
S65
I think it's behind the front bumper, driver's side.
Old Jul 30, 2025 | 08:56 PM
superswiss's Avatar
2019 C63CS
I don't have a pic of he exact location for the S Class, but you should find it low down in the front bumper on the driver's side near the air intakes looking something like this as shown on my car. It's a pointy little thing in a recessed hole.
Old Jul 30, 2025 | 10:26 PM
Alexie's Avatar
The ambient temp sensor on your 2016 S550 is usually behind the front bumper, near the lower grille or fog light area. Check for debris blocking it or a damaged wire. If it's stuck at 82°, the sensor itself is likely faulty common issue. Easy DIY replacement if you can access it.
