S-Class (W222) 2014-2020
Slight Bump On Hard Accel From Stop
Old Oct 17, 2025 | 09:48 PM
vinflouen's Avatar
2019 W222 S560 4Matic/2025 Yukon Denali
Hi All,
When i get on it from a hard stop i hear a bump sound.
like if your in a boat and you hit a tree slighlty.
my flex pack is a little beat up.
the car is not slipping, just a bump sound on launch….
Old Oct 18, 2025 | 03:14 AM
W205C43PFL's Avatar
Originally Posted by vinflouen
Hi All,
Hmmm engine mounts or transmission mount?
Old Oct 18, 2025 | 08:10 AM
vinflouen's Avatar
I just replaced the trans mount.
maybe flex plate?
The disk is looking kinda ‘scratchy’.
streborx's Avatar
Top Answer: 1
G550
Do you have auto start/stop?
Old Oct 18, 2025 | 12:13 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
Check center driveshaft bearing as well.
Old Oct 18, 2025 | 03:47 PM
vinflouen's Avatar
Im going to check the driveshaft bearing.
auto stop start has been disabled by Benz Ninja
Old Oct 18, 2025 | 04:19 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
Back in the day, that was a clear sign of a U-joint going out in the driveline. But these cars don't have U-joints.
Old Oct 19, 2025 | 03:36 AM
W205C43PFL's Avatar
maybe flex plate?
I see, as others mentioned, check the bearing.
Old Oct 19, 2025 | 03:37 AM
W205C43PFL's Avatar
Interesting, they don't? TIL. What was used to replace ujoints?
Old Oct 19, 2025 | 07:45 AM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
There is a u-joint at the center support bearing. However in 35 years of DIY on my Mercedes I've never had to replace one. If your flex discs are in order (front and rear) check the rear end for worn suspension links.
Old Oct 21, 2025 | 03:31 PM
Top Answer: 1
I thought they used unobtanium to connect the flux capicitor to the positronic matrix; that's what the dealer said to explain the repair bill...
Old Oct 21, 2025 | 08:42 PM
W205C43PFL's Avatar
Ah, so the dealership said that.... No wonder
Old Oct 22, 2025 | 08:59 PM
badq45t's Avatar
2016 S550e, 2005 Nissan Xterra 4x4, 1984 300ZX
I had something similar under warranty and it was the flex plate whatever the heck that is!
Old Oct 23, 2025 | 01:56 AM
W205C43PFL's Avatar
Thanks for chiming in.
Old Oct 23, 2025 | 08:32 PM
vinflouen's Avatar
My flex plates are a little chewed looking.
i got new ones from the dealer for about $320.
going to do the install soon.
Old Oct 23, 2025 | 08:43 PM
W205C43PFL's Avatar
Yay so that was indeed it!
Old Oct 25, 2025 | 05:01 PM
vinflouen's Avatar
Does anyone know if i need the car in neutral for this job?
any tips on this job?
Old Oct 25, 2025 | 10:50 PM
VII's Avatar
VII
Neutral and wheels off ground to rotate bolts around, shaft position should be maintained.
