S-Class (W222) 2014-2020
S550 Rear Door Panel
Old Dec 30, 2025 | 09:11 AM
CapsFanBen's Avatar
Prospective Owner
I am considering a used 2016 S550. One of the rear door panels was not properly attached to the door--it was loose all along the top, where the window starts. I am wondering if anyone knows it this could just be a simple matter of replacing clips or if a new (used) door panel might be necessary. I am seeing used panels for only a couple hundred bucks, so not bad, but I am just trying to see if it might be even cheaper than that to fix.
I tried looking at a parts diagram, but so far I have not found a website that is easy to use. If anyone has any recommendations on that, I would appreciate that!
Old Dec 30, 2025 | 10:19 AM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
That is an odd issue. I would assume it is just some clips. Easily sourced on ebay or your local MB dealer. I would wonder why the panel was loose to begin with as they are pretty firmly attached to the door carcase.
Old Dec 30, 2025 | 12:00 PM
xabo's Avatar
'20 S63
Normally there's a ledge that the top of the panel rests upon.
Old Dec 30, 2025 | 12:09 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
Is it at a dealership? If so, I'm surprised they didn't re-attach it prior to listing the car for sale. But liek the others said/showed, it should be super easy to fix. The clips that hold it in aren't expensive so if that's the problem it's still a cheap fix.
Old Dec 30, 2025 | 03:06 PM
CapsFanBen's Avatar
Prospective Owner
Thanks, everyone!
