S-Class (W222) 2014-2020
How to Read the Dashboard Oil Level Display?
Old Jan 17, 2026 | 11:54 AM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
Changed my oil the other day and put in 8.75 qts initially (vs. 9.5 spec) planning to top it off later using the dash oil level display. Of course the owner's manual has zero information about how to read the damn thing. It looks like this ... the "Oil level OK" message is nice, but leaves me wondering what exactly the horizontal lines and 'Min", "Max" lables actually mean?
Old Jan 17, 2026 | 12:08 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
In my S63 I can go into the workshop menu and see the exact level in quarts so I used that to determin what this gauge says. The max fill line is at the bottom of the top section of the barrel. And the minimum allowed is at the bottom of that center section. The S63 takes 9.0 quarts. When I was at 9.2 quarts the level on this gauge was slightly above the max line. At that time, in another menu on my car it said to drain .1 quarts to be at optimal oil level, just a message not a warning. Hope that helps.
Old Jan 17, 2026 | 12:33 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
I would read that as "perfect, don't change a thing"
Old Jan 17, 2026 | 01:01 PM
NbyNW's Avatar
Veteran: Navy
Various
I think when in the workshop menu it gives more info on the level? I could be mistaken. Mine was where yours is and I added a bit to get it up one line. Definitely splitting hairs and sure it makes no difference and where you are is fine, I just wanted it up a line.
Old Jan 17, 2026 | 01:02 PM
superswiss's Avatar
2019 C63CS
Pretty self explanatory I think. Just like the tip of a physical dipstick.
Old Jan 17, 2026 | 02:10 PM
Ok, thanks guys. So the middle two sections are "ok" and the upper and lower-most sections are too high and too low respectively.
Old Jan 17, 2026 | 02:21 PM
SSBN629 Seattle's Avatar
Currently ‘2015 S550 4matic. Previously 03 E320, ‘06 S430, ‘08 S550 4matic
Hi Carlos.
Is this same oil level feature on my ‘15 4 mastic as well?
Old Jan 17, 2026 | 03:02 PM
smiles201's Avatar
2023 E 450 Sedan. 2018 GLC 300. 2013 E 350 Coupe (retired)
Also be aware that it is not like a physical dipstick as it takes time for changes in the oil level to register as a new reading on newer models. And it does not necessarily provide a linear reading. You have to drive several miles to get a good reading on my 2023 E450. And half way between Min and Max is probably less than half a quart.
Old Jan 17, 2026 | 03:05 PM
smiles201's Avatar
Delete
Old Jan 17, 2026 | 03:11 PM
superswiss's Avatar
2019 C63CS
Originally Posted by smiles201
Also be aware that it is not like a physical dipstick as it takes time for changes in the oil level to register as a new reading on newer models. And it does not necessarily provide a linear reading. You have to drive several miles to get a good reading on my 2023 E450. And half way between Min and Max is probably less than half a quart for instance.
That is essentially correct, and it's all described in the owner's manual. Probably should read it. It can take up to 30 minutes or longer depending on driving style, for the oil level to display correctly, so you can't just fill and check as you do with a dipstick.
Old Jan 18, 2026 | 08:09 AM
Any theories on what volume of oil is represented by the range of min to max? On a physical dipstick the min and max marks were often one quart apart ...
Old Jan 18, 2026 | 10:08 AM
SW20S's Avatar
2024 S580
Its probably within one quart since the light comes on when its 1.1 quarts low. Pretend its a dipstick...its just a virtual dipstick. I've never looked at a regular dipstick and wondered what the variance is, I look and see its in the zone and put it back in. As long as its in the range I wouldn't worry about it.
