21” tires and wheels
https://www.alloywheelsdirect.net/me..._saloon_alloys
I have Mandrus wheels that are made for MB, but they are all sold out. There are a lot of third party options. Other option is buying used OEM wheels from upgraders thru the marketplace here, ebay, Craigslist, FB, etc.
I searchd through discussion boards and realized this is a problem with 21 inches wheels. I dont know i he insurance will still pay for it but the bigger problem is everytime I drive the car the tire blows out and i have to wait long time to get the tire and i am incapicitated . I wonder if it applies to the Lemon law and should I ask the dealership to change the wheels to 20 inches and a different tires any advice will be appreciated.
I would first speak with your dealer manager and ask them to swap out the wheels & tires. If they refuse, I would speak with a Lemon Law attorney. Best of luck to you and PLEASE let us know how you make out.
if you do change, I’d go to OEM 19” wheels and tires like many others have done. Pirelli and MBZ are responsible and if you read past posts on this thread, someone is thinking of a class action suit.
Good luck
I know runflats have really stiff sidewalls and I would I guess that the sidewall stiffness is inversely proportional to the sidewall thickness. Maybe the increased stiffness due to the reduced sidewall diameter makes the 21” rft very susceptible to pothole blowouts. I’m wondering if it is enough to simply replace the runflats with non-rft to reduce the risk and issues experienced with the 21” rims versus having to downsize everything. It might be worth a try.
Anecdotal as it gets so to ground that a little bit I just did a search over there for "flat tire", that gave me no results with a flat tire in it. I switched to "blown tire" and got a couple threads; both started by the same man, 21s, Pirelli. Found a couple random mentions with "21 wheel", but 2 of those were the man from "blown tire."
There are a lot less Panamera's sold, different demo driving them, etc. I'm not saying that constitutes proof but the 21s=run away thing wasn't a thing over there. Same with the cars before, sure you read about it, but not like here.
I regret getting rid of this thing. The only reason I dumped it and moved to what was my rattle trap GLE 53 was because the X5 has pitiful rear seat legroom. This thing, however, was an undercover rocket hitting 60 in the high 3 second range. The build quality and fit and finish was so much better than the GLE, hands down.
you are right for one thing you go on atrip the tire blows and you get it towed next you wait a month to get the back order tire which itself is painful.
I will follow the suggestions you made.
https://mbworld.org/forums/s-class-w...buto-i-ih.html
Hope this helps!
https://www.tirerack.com/tires/tires...XLN0&tab=Sizes
Plus warranty company dont know crap. If you replace them with Michelins they are still liable to cover you for tire/wheel damage regardless of what brand is on your car for the duration of the warranty period.
I see MICHELIN PILOT SPORT ALL SEASON 4 -
- Size: 255/45ZR19 104Y XL for $1235 all 4 tires
If you find Michelin Pilot Sport AS Plus N-Spec. You can get them size 255/40R20s which is what I have.
and would recommend to anyone still on 21s
