Adding Heated Steering…Help?
Old Feb 15, 2024 | 10:22 AM
GDOG's Avatar
2022 s580
I just purchased a used s580 without heated steering. I am interested in adding a heated steering wheel. I have searched the forums already looking for info, but haven’t found much relating to the W223. Is this a project that can be done mechanically? I have seen “heated steering wheels” for sale which I understand to mean that they have the heating element which my car may lack. Then I assume I need parts for the column, etc..
If anyone has info that might help, it would be appreciated.
-George
Old Feb 16, 2024 | 08:56 AM
TSA's Avatar
TSA
S580 MAYBACH Z223
yeah you gotta swap the steering wheel with the one that has the heated steering wheel option.
Old Feb 16, 2024 | 10:43 AM
places's Avatar
No more MB:(
Also probably require some software updates and programming. These cars are already challenged and maxed out technically, is it really worth the risk?
Old Feb 16, 2024 | 01:26 PM
GDOG's Avatar
2022 s580
Reasonable question, I really like my hands warm…that’s why I am asking if anyone has done such a thing. There might be some risk, but if people have done it before, I would definitely be interested.
Old Feb 17, 2024 | 04:55 AM
Diesel Benz's Avatar
I could give you mine. My car has it but I never use it.
At least my car has a switch on the steering column. Difficult to say if the switch also needs to be installed, possibly additional wiring. Since steering wheel heating can be configured to work with seat heating, the switch might not be needed (would through a fault diagnostic fault code but unlikely anything on the instrument cluster).
Old Feb 17, 2024 | 07:55 AM
GDOG's Avatar
2022 s580
I will check with my dealer on Monday. I have also asked my local independent MB tuning guy to investigate. I can buy heated wheel and steering column with heated switch port for about $500. I agree, that it seems like it will a manual switch -just a plastic part and wire harness connection. My tuning guy has full access to programming if necessary we will see.
