W223 Active Braking Triggers
Phantom Emergency Active Braking when traveling down the roadway is unacceptable. Maybe it is detecting real ghosts?
I happen to be glancing out the driver side window the other day at 40+ MPH and BAMM...neck snapping active braking occurred for no apparent reason. Clear day, clean sensors and driving through open farm land. I was lucky no one was directly behind me. This unscheduled test of the autonomous emergency braking system gave me whiplash. The system must be monitoring your head position and if your not looking straight ahead, will initiate the active braking sooner if it thinks it senses something in front and/or is coming from the side. Kinda scary now thinking about it happening again, When?
I'll let the dealer know. Just a Heads Up, I mean Heads Snap Forward.
I didn't think about this the other night but I should have checked the dashcam footage to see if there's anything on there or if it at least recorded the active braking action so I can save it to show the service advisor next time. I'll check it next time to see if it hopefully is still on there before it gets overwritten.
