Help needed about the noise from suspension
Old May 28, 2025 | 09:33 AM
W205C43PFL's Avatar
Originally Posted by nearwater4me
If this is an inherent design issue with the suspension component, then why aren't we seeing the same issue on all cars?
If it's just a lower percentage of defective parts then why can't they fix it?
It might be a specific batch or if it really has to do with the salt belt. Can forum members share their build date?
Old May 28, 2025 | 11:44 AM
Ion90's Avatar
The service team replaced several front suspension components, recalibrated the AIRMATIC system, and conducted multiple tests. At one point, they even replaced the front gearbox mount (as a test), but after a short test drive with no improvement, they reinstalled the original part. Despite all efforts, the problem persists. A sharp metallic knocking sound occurs **intermittently** when driving over uneven surfaces, especially under light acceleration or braking. For example, in an underground parking area with artificial bumps, I can pass over the same bump five times — one or two times it behaves as expected and absorbs the impact smoothly, but on the other three passes, a strong metallic impact occurs in the front suspension, as if metal is hitting metal.
Old May 28, 2025 | 11:50 AM
nearwater4me's Avatar
'25 S580
Wow, okay.
So this could be something other than a simple faulty bushing and more so related to the adaptive suspension and its behavior.
Either way keep us posted on how the investigation progresses.
Old Oct 9, 2025 | 11:15 PM
Kent agent's Avatar
S600 w222
Had similar on my lexus LS600hL before and replace struts and shock absorber front no betterfinally I figured out the fault and it was a brake pad that was loose and causing this annoying noise
