Parallel parking wreck
I had a Lexus ES when that happened (the driver in that case was driving a loaner ES350), and I remember the dealer confiscated my Lexus OEM rubber mats and they took a saw and cut two notches out of the bottom of my gas pedal, all without my consent. I was FURIOUS and I got them to give me my rubber mats back, but unfortunately the damage to my gas pedal was done.
OP: This is terrible but am glad everyone is safe.
We have had similar experience with our GLS but the complete opposite. The accelerator lost 100% of it’s signal right before an intersection. Now I don’t want someone to tell me oh it was the brake or whatever..lol… cause it wasn’t in that case obviously. The event lasted 20-30 seconds, all while the engine is idling firm and all recorded on our dash videocam with cabin sound… Luckily we were able to make it to the other side (car momentum rolling), all while the car was 100% running and engine idling.. just no accelerator response whatsoever as of the engine is off but not. Once the car arrived the other side of the intersection with emergency/hazard indicators on, turned off the car, turned on again, and things are back to normal. Dashcam was very handy. We took it to the dealer, shared all videos, and they could not figure out at all what is going on (oh we couldn’t duplicate it …we updated the software… oh sure!). I posted about it in the GLS forum. And for the record, there are dozen of reported issues of the same, some experiencing it on the highway!.
.Like Peter Ubers says, if it can get stuck in idle, it can get stuck at 100%.
Losing connection to the throttle sensor is a totally different thing than having a false signal sent by the TPS.
You would think that after (I bet) hundreds of reports like this Mbenz would do something or care and issue a recall just to be safe…. Well not when their OTA game is trash. One quick google search and you will find dozens, and one Cargurus post alone has over 20 owners of several models reporting the same, and some of them reported the issue happened 3 times even after useless TSB software update… instead of taking this seriously and even issue a recall for each and every car, they only issued a TSB that they updated twice, once every four years, from 2014 to 2020, and haven’t updated it yet in 2025 for any of the 2020-2025 model years. And again, you would think they would take a fatal issue like this seriously, but they are more focused on their EQ/EV line, leaving customers at risk with poorly designed electronics and low-quality flagship cars that can strand you anytime, anywhere. I don’t care much about the build quality in a family car, but I don’t want it to get stranded or lose the accelerator padel. I was told they updated the software but couldn’t replicate the issue anyway. I’ll take them for their words for now and we’ll be extra careful (it’s good that we know what we know and can prepare mentally if it happens again), there is nothing else I can do meanwhile.
Car recently serviced with battery replacement. Further info: no audible beeps from distance warning system at any time, car initially wouldn’t move into reverse when maneuvering. After several attempts it finished its rearward part of the parallel parking. Thought this odd but assumed some sensor had picked up sign further behind car. Went then to move forward to finish parking. Car initially wouldn’t drive and wouldn’t move. Car directly in front of spot I was parking in so thought sensor had registered this but still no audible warnings. So shifted in and out of drive and tried again. Still no going forward. Same thing had happened in reverse so in and out of drive again for my 3rd (and final) attempt. This time when I applied gas the car lunged forward and events transpired as reported in initial post. I honestly believe it was a combination of failed technology and human error. I didn’t stop and restart car. Maybe that would have changed outcome.
Whatever happened I hope it never happens to you!!!
https://www.mbusa.com/en/owners/manu...ve-away-assist
Were you attempting a manual parallel park or were you using the automated self-parallel park feature?
The automated one, which I think you were using is doing all sorts of calculations and processing of sensors as you said and realize - and it detected issues with obstacles and angle of the wheel or something so it seemed to halt everything. At that point you could cancel the process and park manually.
I am glad you are ok and not seriously hurt. Thank you again for sharing
car is a 2023 S500 having just been serviced for new tires and routine maintenance.
you say you were parking "manually"
then you say the car needed to "finish the rearward part"
can this be defeated? How would one "rock out" of a snow bank?
Thanks for sharing and for your candor. Could it have not responded two times as it was in a collision avoidance mode? Or a wheel stuck in a small rut? And the third attempt served to either over ride the collision avoidance system or overpower the stuck wheel.
