Ceramic Pads
Old Feb 1, 2026 | 12:03 PM
sach22's Avatar
15 S550 4Matic, SLS AMG Gullwing, Previous: Every S Class, SL, 190E, C Class. '16 AMG GTS
Ceramic Pads
Hi All,
Wanted to replace the brake pads on my 2022 S580 4Matic Sport with ceramics to reduce the brake dust.
Has anyone done this and what pads would you suggest?
Thank you!
Old Feb 1, 2026 | 12:08 PM
acatt's Avatar
S580
Can you use ceramic pads on regular rotors, or do you have to replace both? Just FYI, I find my ceramic brakes annoying as they frequently squeak. I’m told this is common if you don’t drive the car hard.
Old Feb 1, 2026 | 12:11 PM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
I’ve had Powerstop Z23 ceramic pads on my W222 for 2 years/33k miles. Much less (almost none) dust, slightly softer initial bite upon application, but still activates ABS if firmly applied.
Very cost effective as well. Check Rock Auto for prices.
It’s no problem to use ceramic on your existing rotors. That’s what I did. No noise at all.
Old Feb 1, 2026 | 04:29 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
I'm surprised you have issues with brake dust. I have none on my S580, where it was a huge issue on my S560.
Old Feb 1, 2026 | 04:31 PM
dmatre's Avatar
I wonder if it’s an issue of multiple suppliers for the same part. I always used MB pads on the wife’s E350. Three sets had minimal dust. This set dusts like the original pads on the W222 - wheels are black after a trip around the block.
Old Feb 1, 2026 | 05:08 PM
SW20S's Avatar
2024 S580
Weird! I figured it was the regenerative brakes on the S580 that kept the dust away
Old Feb 2, 2026 | 07:22 AM
Sparky66's Avatar
W167 2021 GLE63S, W223 2022 S580
My AMG GLE63 (red calipers) is horrible about dust / rust where my S580 it is a non issue. Really what suprises me is the on the AMG even though the dust / rust has always been a nightmare the pads are lasting just as long so I assume the cause must be the rotors on it
Old Feb 2, 2026 | 08:03 AM
Mem30306's Avatar
2023 S580
My 2018 E63 with non-ceramic pads had terrible brake dust, but my 2023 S580 has no observable brake dust.
Old Feb 2, 2026 | 10:11 AM
ldramg's Avatar
‘26 S63, ’19 E63s wagon; prior: SL55; CLS55; G63, GT-R
My 2026 S63 (with iron rotors) is terrible on brake dust (even with VERY modest brake-in driving going on). My E63 with full ceramic rotors and pads, basically none. The S throws off significantly more dust, even than my very heavy ‘21 Defender. When the time rolls around to change pads, I’ll look for a lower dust option for sure.
