Maybach Mode Coding...excellent...
Old May 12, 2026 | 06:01 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
So I had @EleBest code Maybach mode for me a few months ago. Originally I didn't use it much because the screen was saying that the suspension mode remained in Comfort:
But when it was mentioned in the GLS forum that Maybach mode there does change the suspension settings I decided to try it out. It absolutely does. I am pretty amazed by the difference in ride quality over Comfort. It also constantly adjusts the height of the car, and below 50MPH or so it puts it in high suspension mode and then back over 50MPH or so it lowers it back to 0, and then at highway speeds it does lower it to -1. It also leaves it in high suspension mode when parked which makes getting in and out of it easier. I suppose the higher suspension mode at lower speeds is to give it better suspension travel. The ride is considerably flatter at all speeds, its hard to describe but its positive.
The transmission tuning also is much "lazier", it truly starts in 2nd gear the way my S560 did, and the transmission wants to shift a lot less which actually helps with the wonky shifting 9G tronic.
My only concerns are its using the compressor a lot to raise and lower it...longevity of that part? I also think the car looks goofy in high suspension mode and around town thats the mode its going to be in most of the time:
But very pleased, I highly recommend having this coded on, especially those who have issues with ride and trans shifting
Old May 13, 2026 | 06:11 AM
DonS550's Avatar
2021 S580 4MATIC with Rear Executive Seating Pkg. 4D Entertartainment Rear Screens Pkg.
I also had it done but have never kept it engaged past 50mph. It’s good to hear it automatically disengages and returns to normal at that speed. I also like the height around town and at department store parking lots.
Old May 13, 2026 | 09:29 AM
SW20S's Avatar
2024 S580
Leave it engaged, it does lower and it continues to provide a different ride profile on the highway which is excellent. Lowers it to 0 at 50 and to -1 at about 70.
Old May 13, 2026 | 12:58 PM
nearwater4me's Avatar
'25 S580
Thanks for the update, Steve.
I recall asking for your feedback when you first had it coded.
Interesting setting for sure!
Old May 13, 2026 | 05:18 PM
SW20S's Avatar
2024 S580
Driving it around more today, the way that it keeps the passengers inside from moving around is pretty amazing!
I don’t like that it sits in high height mode all the time under 50 MPH because it looks dumb, but it rides so great…
Old May 14, 2026 | 07:49 AM
Mem30306's Avatar
2023 S580
Steve, it sounds like it is doing many of the same things that E-ABC does. Nice!
Old May 14, 2026 | 08:39 AM
SW20S's Avatar
2024 S580
I was thinking the same thing!
Old May 15, 2026 | 10:36 PM
superangrypenguin's Avatar
A car
This is really cool how it can be coded after the fact. Do you think it adjusts the actual spring rates too?
Old May 16, 2026 | 01:07 AM
SW20S's Avatar
2024 S580
I can't say for certain but it seems to adjust the damping/spring rates.
Old May 16, 2026 | 05:40 AM
docsout's Avatar
2023 S Class 2013 SL
Would you take several pictures of the sides of the car so we can see what you are describing as increased height.. Perhaps also a pic of the wheel wells just to demonstrate the difference. Thanks.
Old May 17, 2026 | 05:33 PM
Jlreyes18's Avatar
S500 2023. Prev. E350 2022, E300 2018
What about warranty?
ok you got my full interest now. It sounds very nice. But, what about the warranty? I have a 2023 S500 CPO with extended warranty for three more years. Does this code (or any other) violate the terms? If not. What would be the cost and procedure to perform this code?
Old May 17, 2026 | 05:44 PM
A car
We're now 12 posts in and still no one has mentioned the crazy amount of drycleaned dress shirts the OP brought home
I LOVE THAT GREY. I'm pretty sure that's Selenite Grey? It's the perfect shade of grey.
Old May 17, 2026 | 06:52 PM
Mem30306's Avatar
2023 S580
I’d say Steve’s dry cleaner has put his children through college just on his dry cleaning bill alone.
Old May 17, 2026 | 08:30 PM
SW20S's Avatar
2024 S580
I wouldn’t worry about the warranty. It can always just be coded back off if it has to go in for warranty work.
Haha. Yeah Selenite Grey.
Haha without a doubt
