Question for folks who upgraded to 20" from 19's
Old Oct 31, 2008 | 09:09 PM
irieblue's Avatar
2007 S550 AMG with ABC
I have an opportunity to upgrade from the AMG 19" Wheels to the AMG forged 20" Wheels off the 2009 CL65. Basically going from 275x40'x19's to 275x35'x20's. One of the things I am most concerned about is ride quality, and if there are any other things to consider regarding offsets, and significantly increased rolling weight. Any suggestions as to the pros or cons of this upgrade?
Old Oct 31, 2008 | 10:54 PM
TMC M5's Avatar
'14 E63S & '14 Audi SQ5
Do you know if the 19's are cast or forged. The forged 20's could actually be lighter. The 19's with the 275/40's are 27.66" tall and the 20's with the 275/35's are 27.58" tall. So you will only be effectively changing the gear ratio by .0029. This is a minimal difference. The 35 apsect ratio isn't that bad of a sidewall. Yes you will feel road imperfections a little more...just be a little more cogniscent of the potholes and bumps. The CL's have an offset of I think 44, some people have found that it isn't exactly the same as an S-class. I would try testing it out first to see..I personally don't like spacers.
Tom
Old Oct 31, 2008 | 11:56 PM
irieblue's Avatar
The stock 19" wheels I have are cast. Digging around, I found the following mercedes Hong Kong web site which allows you to configure an S Class with various AMG wheels...
http://www.mercedes-benz.com.hk/cont...loywheels.html
It looks like the 20" forged wheels are available as an option on the S class.
