No power off the line in tt v12
Old Aug 20, 2009 | 05:36 AM
2003 S600's Avatar
2003 s600
I just got my car back from body shop and I floor it from a stop and it upshifts, does not spin wheels and no power off the line. What could be the problem? They replaced all radiators, oil cooler, heat exch, ac condenser, rad fan. Tranny fluid level ok. All vacuum hoses look ok. This has kleemann ecu/tcu so it normally lights up tires even with esp on.????????
Old Aug 21, 2009 | 06:16 PM
Iceman's Avatar
E55
Check the transmission mode...if it is in W mode it is starting in second gear.
Old Aug 21, 2009 | 09:22 PM
2003 S600's Avatar
2003 s600
happens in all modes, even worse in c mode which used to be w mode. turbos are not making enough boost in 4000 and lower rpm.
Old Aug 27, 2009 | 05:15 AM
2003 S600's Avatar
2003 s600
Had dealer run codes and diagnose, boost and tranny codes came up: P2001 Charge pressure too low and P2318 One or more messages from control unit N15/5 (Electronic selector lever module control unit) are not available on the CAN bus. (CAN timeout fault) ---both current and stored. Anyone know what I need to do?
Old Aug 27, 2009 | 08:03 PM
bp95gsx's Avatar
S600 Bi-Turbo/E39 M5
Maybee the body shop did not bleed you intercooler system properly. That could make your car feel like a dog.
Old Aug 30, 2009 | 02:32 AM
2003 S600's Avatar
2003 s600
dealer did that. wastegate rod nut fell off.
