>>The ACT Reservoir - Active Cooling Tank Available<<
Old Aug 26, 2009 | 06:40 PM
ChicagoX's Avatar
Former Vendor of MBWorld
W211 E55
ACT - Active Cooling Tank
LET Motorsports is pleased to announce availability of the next part for those seeking maximum performance: The Active Cooling Tank, or ACT.
The 55/32 Kompressor motors, as well as the 600 and 65 Biturbos use an air-to-water circuit to provide cooling of the intake charge. This charge-cooler circuit, sometimes referred to as the intercooler circuit, gets heat-soaked rapidly in stock configuration. Modified cars running more boost heat-soak even faster – ultimately reducing performance!
A larger front-mount heat exchanger (FMHE) helps a great deal, as it adds fluid volume to the circuit and recovers faster than the smaller stock unit.
The ultimate solution? The Active Cooling Tank.
This trunk-mounted reservoir is the best for 3 reasons:
1) It increases the total fluid volume of the cooling circuit by XXX liters
2) It allows for ice to be added to the circuit, increasing efficiency to GREATER THAN 100%
3) The ACT has a second, separate interior tank for dry ice – you can run BOTH !!!
Details include:
Fully insulated double wall construction – billet brackets – AN-10 swivel fittings – large access ports for ice – welded drain port – screened outlet – integrated heatsink on dry ice tank – downtube for CO2 evacuation – top-quality materials and construction throughout – 1 year warranty
The ACT kit includes all fittings, hoses and brackets required for install. Also included is a circuit separation kit, to eliminate the crossover pipe to the engine's coolant.
Due to the unique shape and design of the tank, there is sufficient room to place a supplementary pump (+$175) or nitrous bottle in the remaining area of the spare tire well.
Pricing has been set as follows:
ACT tank only: $ 499.99
ACT tank kit: $ 649.99
ACT tank + pump $ 824.99
(Prices do not include shipping.)
We are now taking orders for these vehicles:
E55 – CLS55 – SL55 – CL55 – S55
SL600 – CL600 – S600
SL65 – CL65 – S65
C32
Estimated delivery in 1-2 weeks
Pics:
Top:
Side:
Screened outlet:
Trunk pics (E55):
Old Aug 26, 2009 | 07:27 PM
Reckless's Avatar
German vehicles stink, will never buy again. Moved on to Toyota and BYD.
Will this void my warranty? How much to install (I am in Chicagoland)?
Old Aug 26, 2009 | 07:54 PM
ChicagoX's Avatar
W211 E55
I have heard nothing but praise from the Mercedes Service Advisors who have seen our cooling upgrades. This makes no change to any emissions hardware or calibrations, so I doubt this will affect your warranty status.
I would budget 3 hours of labor to install. EuroCharged is $65/hr, dealer is $110/hr.
