ABC issues, Oxygen you out there?
Well my S55 is having a few issues with the ABC. The right front strut had a leak so I went ahead and had it replaced and flushed. That cost over $2,500. I also am having a problem with what I believe the pressure sensor for the ABC. The car randomly comes up with the red warning saying ABC drive carefully. When they were doing the strut replacement they saw the warning come up and checked the computer and there was no pressure readings. That is when they said that it may be the pressure sensor. I didn't have time to wait since I was in a wedding and HAD to take the car and go.
The car still drives fine BUT the car will not lift or anything like that. It does hold the same hight and handle OK I guess just seems a bit bouncy. So what do you think? Oxygen you seem to be a pro at this what is your opinion? Remember the warning is only random and sometimes the system works just fine.
Thank You
Johan
In anycase, if your car is handling "OK" but is bouncy, that means that the ABC system has switched on the passive mode and is basically shut down and just keep the struts up so you can drive it to wherever you have to.
I would sometimes blame this on low fluid level but if your system was just serviced then that would not be the case.
just complaint blah blah blah..after you guys replace my strut..abc light comes on etc...
yeah like oxygen said..and there's alot of stuff on the car that can fail..so try to get the code asap..maybe post it here ?
Johan
because i have 2003 model also..recently my white abc come on intermittently also..*(same as you)...i haven't have time to go get it scan.. yet..
im suspecting pressure sensor also..
