ABC error code C1129..
i just had my white abc light scanned with a star diag...
the code is c1129... right rear plunger failure..
we looked at the current spec reading.. wow it was off...
there's two plunger in the front strut and one on right rear strut...
any of you guys have this code before? if so, what's the fix? any alternative? since the sensor is inside the strut...i was advice to replace right rear strut...
any advice?
thanks..
dumas55
any advice?
thanks..
dumas55
I had a perfectly good strut with a failing sensor on my SL55 once. Replacement was the only solution. Since the strut is non servicable and the sensor is inside you are S.O.L. AFAIK
cool, thanks for reply, i just want to make sure im not only one with this failure..
i will looking into replacement of right rear strut soon..
oh no
any advice?
thanks..
dumas55
any advice?
thanks..
dumas55
