S55 Engine noise, and how to get power?
Old Nov 13, 2009 | 08:52 PM
rondocap's Avatar
Mercedes S55 AMG
I have an S55 AMG, 2001. I noticed that depending on where the MPH or RPM's are, it will give more or less of a power response when you push down on the pedal.
Sometimes, it won't react much - other times it really picks up and goes. How can you time this so you know what is going on and when the engine will respond with the full power and thrust? I have not fully figured out yet.
Also..is it normal to have a higher pitched engine whine on the S55 2001? It's NA so there is no supercharger whine..
Thanks!
Old Nov 14, 2009 | 03:26 PM
sprins's Avatar
G55, SLS, smart eq
AMG engines from that time tend to whine. My (former) ML55 (same engine as yours) also whined. No worries there it seems.
About the 'pulling'. When you shift manually and keep the revs high and the gears low, it should always pull to the max. In automatic the transmission computer doesn't always (although usually it will) know what you want. So try manual for a while.
Old Nov 15, 2009 | 09:37 AM
Zachmac's Avatar
2007 S600
Thanks!
The best way to get power is to buy a 2003 to 2005 SC car!
Old Nov 15, 2009 | 06:00 PM
hegar817's Avatar
2003 s55
LOL.. Just that simple!
Old Nov 15, 2009 | 08:28 PM
Viet_Amg408's Avatar
Pinto
no u wrong lol..
get s65 or s600...03-up of course
