S55 Wheel Fitment Question
03 S55 AMG
I'm looking at buying a set of used HRE in the sizes below and wanted to know if they will fit my 03 S55 properly. Thanks!
Fronts:
20" rim
+31 offset
6.5" inner barrel
2.0 outer barrel
Rear:
20" rim
+40 offset
7.0" inner barrel
2.0" outer barrel
Fronts:
20" rim
+31 offset
6.5" inner barrel
2.0 outer barrel
Rear:
20" rim
+40 offset
7.0" inner barrel
2.0" outer barrel
PLATINUM SPONSOR
Use an online offset calculator and that will help. The offset you listed for the rear should be fine but not sure on the front..
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
The backs are fine as you are only 4mm off OEM (44mm) which is less than 2/10ths of an inch. The fronts are where it will be tight. You are changing there by 13mm or about one half an inch. This is going to put the tire further out by a half inch which with 20's could bring some fender into play. It will be close. What tires?
