Squeaking Supercharger
The squeak is coming from the belt slipping when the mass of the supercharger is connected by the clutch immediately instead of slowly so i figured a different belt and/or more tension will do the trick.
So i got a new tensioner and a better belt (tried the dayco belt and it sucked) and so far no squeak and the lag when the supercharger engages is smaller as well.
So for everybody that has this problem this might be the cheaper fix since the new clutchpack costs $1100.
The belt i used is a Gates K080505HD and you can get it from amazon.
Good luck....
I am glad it worked out for you though.
Good luck....
the supercharger belt squeaks and clutch pack chirp is totally different....i think you mix it up there buddy
