S Class AMG products (Vaeth)
Old Mar 12, 2011 | 03:38 PM
VaethSales's Avatar
Former Vendor of MBWorld
Mercedes Benz
Hello everyone,
I'd like to showcase some Vaeth products to the S Class AMG crowd. These parts shown are for the S63 AMG. For the S65 AMG and all other S Class parts, please click HERE
Brake-Optimization
Brake line kit and racing brake fluid Castrol SRF.
High-Performance Brake System
390mm brake disc at the front axle with 6-piston brake caliper and brake lining set as well as racing brake fluid Castrol SRF and brake line kit.
Attention: At least 19" inch tires necessary at the front axle.
Limited-slip differential
Improved traction and acceleration, improved cornering ability. For road and race track.
Silencer System made of VA High-Grade Steel
2-pipe rear silencer system with 2 exhaust pipe ends each side. The pipe ends are high-gloss polished and chrome plated, ca. 90mm diameter each, round or oval. Sonorous, deep sound. Noble appearance over years.
Carbon Front Spoiler
For optimization for aerodynamics, less ascending force. Sporty, noble appearance. Consisting of high class carbon.
Front Spoiler Lip
Consisting of glass fiber composite material. Sporty premium design. Primed.
Rear Diffusor
Consisting of high class carbon. With fins and larger underbody.
Only in conjuction with Sport-Package AMG (Code 950).
For limousines and station-wagons.
Rear Lip (for trunk)
Consisting of PU-RIM. Primed.
Carbon Rear Lip (for trunk)
Consisting of high class carbon. For limousines
Fender
Consisting of glass fiber composite material. Sporty premium design. Left and right side. Primed.
Side skirt
Carbon Interior
Classic design of carbon in black for interior refinement. Highest processing precision and perfect fitting. Handmade in Germany. In exchange for your original parts. Additional charge for colored or multicolored
carbon.
Consisting of:
- Climate visor
- Ashtray cover in front
- Gear shifting gate
- Gear lever knob
- Door visors
- Seat adjustment on the right, on the left
Sports Chassis (Active Body Control ABC)
Elegant optics: Lowering in third damper level sportive-tight. In first and second damper level comfortable. Improved cornering ability.
Fuel Cooler
Cooler fuel has a higher density. Efficiency improves clearly. Much better combustion guarantees excellent exhaust values, less fuel consumption, lower temperature in combustion chamber and more power. For highly required engines and for all those customers, who want to foster their VÄTH- or Mercedes-engine exceedingly. Including tubes and fittings.
Engine Oil Cooling System
Transmission Oil Cooling System
We also offer engine tuning as well.
Please visit Vaeth.com for more information.
