Help me connect my iphone 4
from the manual:
There are 2 kinds of reset that you can do on the ViseeO
Standard Reset
When the unit is plugged into the car (and the car ignition is switched on) press and hold the reset button (4th button down) for 7 seconds and then release it.
Master Reset
Switch off the bluetooth on your phone and remove the ViseeO connection from it
Plug the ViseeO into the car socket and switch on the ignition
All the lights should start flashing
Press the sync button (2nd button down) and hold it for 6 seconds
Whilst still holding the sync button, press the reset button and then release them both at the same time
All the lights should come on solid for a second, before going back to flashing
Once that is done the ViseeO should be back to the factory settings so you should be able to pair and sync your phone up to the ViseeO.
Good to see you are still around dude. Did you ever figure out how to launch that E? I'm guessing you just gave up and bought that all wheel drive ride that any old lady could launch. All jokes aside I hope you are doing well bro! Good to see you are still hangin' around here.
You are way ahead of me. I’m still old school with an Iphone 4 and a lowly E55. I hope to have a new TT CLS or E63 estate soon but I find myself losing focus when I spend too much time in the men's bathroom.
Anyway, all is good bro and it’s nice to see you back in a Mercedes. BTW, I have been working on my launches and one day I will make you proud.
I always figured you as a guy that would be happy with his walkie-talkie.......go figure.
