Trunk tank and pump flow combo.
PLATINUM SPONSOR
I have done a lot of cooling flow test over the last few years and this is what I found to be the best set up on the CL/S class system.
First, a lot of people claim that you can buy to big of a pump and flow water to fast and hurt IAT`s. I never believed that and found it to be BS. Our stock size lines will only allow so much flow and that will not hurt IAT`s. You need to flow water fast and all the pumps we all talk about , will not flow TO FAST.
First, an auxillary H/E added to the stock H/E is a good mod. Then use Mez front pump, with a Rule 2000 pump located inside your rear trunk tank. I have a 4.7 gallon tank and can not find any reason to run a larger tank than this. After a full mile run, I still have 50 degree water temp. in the tank but all 20lbs of ice will melt. In a 1/4 mile run, there is still enough ice for another run.
The front Mez pump loves the push pull system of the Mez/rule pump combo. The rule pushes water and the Mez pulls, creating a flow syneregy of sort. Even with all this, flowing 5.5 gallons per minute in our lines, is about the max you can attain with these large pumps.
My trunk tank is also desinged to fit inside my spare tire and out of sight.
![](http://i991.photobucket.com/albums/af31/Vitabc/utf-8BSU1HMDA5MjgtMjAxMTA3MTQtMTkzMy5qcGc.jpg)
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
PLATINUM SPONSOR
Thanks! Love your top tanks! Great work bro..My ported heads will be on soon and they flow over 350 CFM at near stock lift! Chevy cant even do that at 700 lift. lol
__________________
www.ultimatepd.com
www.ultimatepd.com
Can't wait to hear more results from them brooke. Keep us updated!
