Made it out to the drags!!!!
1 Post
S55 AMG
Well, I finally made it out to the drags last night. All in all, it was a good night. NOTHING BROKE!!!!! Way happy about that. the night started with a descent run with a 12.54@113.88mph. My next run was 12.52@113.08mph. Then my last run was the best of the night. Everything came together for me. Launch was good, reaction was pretty good. Well as everyone always says, pictures or it didn't happen. So here you go.
My info is on the left and total weight of the car with me in it and out was 4670lbs with an 1/8 tank of gas. And without me it was 4475.....I could stand to lose a little weght. My car has Kleemann headers, kleemann ECU tune and ASP 180mm pulley kit. Also I did the grill cut out as well....hoping for a little better air flow. I have yet to dyno, but I would imagine it is around the 500rwhp mark. Thanks
PLATINUM SPONSOR
Nice, good to see more 55`s making it out to the track. Work on your 60 ft time, traction, launch method and times will drop a lot .
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
1 Post
S55 AMG
Thanks, I just made plans to head out again here on the September 2nd......so we will see what happens there. I still had more pedal left on the launch, and traction was good that night, hopefully traction will be good this up coming night.
