2010 S63 Weistec ECU Tune "Problem"
Old Sep 19, 2012 | 08:57 PM
bobbyjames's Avatar
2010 S63 Kleeman Longtube Headers, Deleted Cats, Weistec ECU Tune
I just received my ECU back from Weistec and was excited to add 47 hp at the wheels. I reinstalled the ECU and also added new K&N drop in filters. When i got out on the road and accelerated the car had major hesitation and bogged down then began to accelerate. I switched over to sports mode and the hesitation was much less but still not as responsive as you would expect. The next day the check engine light came on. The codes are P0171 too lean and P2187 too lean at idle. I had the codes cleared and am faced with re flashing the ECU back to factory. Has anyone had any experience with ECU problems after flashing?
Old Sep 20, 2012 | 10:42 AM
KUNMB's Avatar
F10 M5, 08 S63 Majestic Black Metallic, 09 CLK63, silver
Need to change back stock filters, ECL will be off.
Old Sep 22, 2012 | 02:42 AM
sakodik's Avatar
E-Class
I had no problem after OE tuning flashed me. But I did run into problems when I sent my ecu and tcu to eurocharge. Had CEL and solenoid problem and had to be towed to my indy.
