2006 S55 Catalyic Converter needs to be replaced
Called around to 5 different Muffler shops and they say that there are no after markets Catalyic Converters for this car.
Any one else with this problem?
I have the check engine light on. My mechanic said that the error code was of the Catalyic converter.
Will the straight pipe get rid of the check engine light, also will I be able to pass smog when the time comes?
Have 106K miles on the car already. Not sure if secondary or primary but guess it is the primary.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
