suspension issue ?
Old Jun 2, 2013 | 08:57 AM
AmorSrdanovic's Avatar
2015 S65 AMG
suspension issue ?
the back right corner of my s65 sits a tiny bit lower then the opposite side, a little more then half the width of my finger. i dont get any warning lights about the suspension and the car raises normally when i want it to but still has the small difference, tires dont rub or anything, i thought it was compensating for my weight when im in it (240). is this something i should worry about? or should i replace the shock now, I've seen a replacement shock for about 660.
Old Jun 18, 2013 | 03:40 PM
evansw220's Avatar
'01 S500 AMG Sport, ABC,Distronic,Rear Side Shades // '10 E350 P2, Pano, BLK/ALM,4MATIC Sport
The system keeps the level at any surface the vehicle is seating when the engine is running thats why may not see the same wheel gap all around unless you are on a level surface. your car is equipped with the ABC system which is way more advance than the AIRMATIC system found in the non-AMG models or 4matic models.
