I'm looking at a 2006 S55 and have a couple questions.
Old Aug 12, 2013 | 06:58 PM
grant.d.nielsen's Avatar
S55
I'm looking at a '06 S55 with about 67000 miles. The service records show three entries for "Body electrical system checked." Is this an issue? The seller says it's a standard maintenance check, but it has been done sporadically. Anything specific I need to look for or know about this car?
Thanks for your help.
Grant
Old Aug 12, 2013 | 07:56 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
That can just mean they ran a scan of the whole system at the dealer but may have been owner driven. These cars can have all kinds of little fault codes that do not effect the operation. Usually just clear them and drive on.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Aug 13, 2013 | 05:08 AM
jwalther's Avatar
Sent you a pm/email.
